Dummy Commenter feature
Send test comments to check the app's behavior when comments are received.
The Dummy Commenter simulates comments without actually streaming, so you can check how they'll be displayed. ※ This does not guarantee connection to or display on each platform.
How to use the Dummy Commenter
Select a platform and press the "Send" button to send a test comment.
Test comments are also sent to the app itself, Templates, WordParty, and more, so you can check how they're displayed and any on-screen effects.
Screen overview
ServicesGift/SuperChatOFFONGift TypeSuper ChatCurrencyOthersNew CommentRepeaterMembership (YouTube)SpeechUsernameTestUserCommentsSend
| Item | Description |
| ① Service | Select the platform to simulate. ※ The data format of the test comment matches the format of the selected platform. |
| ② Gift/SuperChat | Whether to treat it as a gift comment |
| ③ Gift type | Select the type of gift. ※ The available gift types differ by platform. Added "Membership Gift," "Membership Gift Receipt," and "Jewel" for YouTube, and "Subscription Gift" and "Subscription Gift Receipt" for Twitch. |
| ④ Currency | (⚠Only active when YouTube is selected) Select the currency for the gift/Super Chat. ※ When Jewel is selected, the price and currency fields are disabled. |
| ⑤ Price | Specify the gift's price or point amount here. ※ When Membership Gift or Subscription Gift is selected, this changes to specifying "Gifts Count." |
| ⑥ New Comment | Treats it as a New Comment (if Repeat isn't checked, it's treated as a first-time comment) |
| ⑦ Repeat | Treats it as a returning viewer's comment |
| ⑧ Membership | Treats it as a membership/subscription comment |
| ⑨ Speech | Reads the test comment aloud |
| ⑩ Username | Specify the author name for the test comment |
| ⑪ Comment | Specify the content of the test comment body (if left unspecified, a randomly chosen built-in comment is sent) |
| ⑫ Repetition (ms) | Specify the interval between comments when sending repeatedly |
| ⑬ Repeat sending | Start or stop repeated sending |
| ⑭ Send | Sends the test comment |
※ Comments sent as test comments remain in the app, so use "Clear comments" on the main screen to remove them once they're no longer needed.
